Laptop fan sound is too loud on idle
Solved by NerdyCoder,
1 minute ago, ZM Fong said:Open task manager and check what program is utilising the CPU.
While idling the CPU usage should be a few percent.
I found the problem: A program called Airdroid took up 18% of the cpu usage. After closing that program, the cpu usage went down to 3%.
Featured Topics
RvG Iced ·
Rogers24 ·
Posted in Troubleshooting1 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1 -
5
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices6 -
6
