Help Building Plan
3 minutes ago, GrimReapez said:Nice , but question , if i buy a tier 1 PSU like EVGA or CoolerMaster , how do i know that it will fit my case or have the right plug ins for my Motherboard/VideoCard? the right pings for it , are the PSU universal? or are they for specific cases and stuff , and if they arent , could you recommend me a PSU for my case/Motherboard/GPu? , i currently own a Raidmax Horus ATX-322WB ,
All PSU's have dedicated cables for motherboards and GPU.
The PSU's are, as you said, universal. ESPECIALLY at tier 1, you get what you pay for.
I can use my EVGA G2 (tier 1) paired with my GTX 1080 and swap it out for an older GTX 460 with the same power cord.
The only thing you'll have to keep in mind is basically the labels on the cables.
VGA=GPU
CPU=MOTHERBOARD HEADER
MOTHERBOARD=MOTHERBOARD
Getting it wrong is pretty hard. It's like those kindergarden puzzles, circle goes to circle, square to square.
As for your PSU, please get a new one. That one is most likely tier6/7.
On that Tier list I recommend everything from Tier 3 and up.
The GRAY labeled CXM series from corsair seem to be a popular "budget" choice nowadays, it's tier 3 and is reliable.
NOT THE GREEN, they are trash.
