I'm planning on completing my first build soon I have a proposed system but wanted to know if it was good or if I could get it any cheaper.
You can find my build here: http://amzn.eu/hS4rwPp
But I can get the CPU, GPU and PSU cheaper here:
http://www.ebay.co.uk/itm/like/262860800270?clk_rvr_id=1170943522428&vectorid=229508&lgeo=1&item=262860800270&rmvSB=true
http://www.ebuyer.com/753819-asus-geforce-gtx-1070-8gb-gddr5-dvi-d-hdmi-displayport-pci-e-graphics-card-strix-gtx1070-8g-gaming
http://www.ebuyer.com/730210-evga-750-gq-modular-gold-rated-80-power-supply-210-gq-0750-v3
1. Budget & Location
I am in the UK so use GBP and I have a budget of £1500 but if it can be closer to £1000 that would be much better
2. Aim
I am planning on using the PC for gaming on games such as, GTA 5, CS:GO, Rocket League etc, but I will also be using it to record and render YouTube videos
3. Monitors
I plan on running 1 monitor preferably at 1080p and 144Hz
4. Peripherals
I only need a monitor for this build
5. Why are you upgrading?
I am upgrading due to the fact I currently only have a HP pavilion notebook which cant run the games I want it to at anymore than 20FPS and it cant render any YouTube videos at all when recording using OBS
Any advice is appreciated
Thanks in advance, Thomas
https://linustechtips.com/topic/746771-first-build/
2. Aim
3. Monitors
4. Peripherals
you can get windows 10 free to safe like 120 pounds
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/746771-first-build/#findComment-9458304
2 minutes ago, tinyman1199 said:
I haven't included windows 10 in my price I have a disc with it on so just need to find a product key
Thanks though
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  (£279.90 @ Alza)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.94 @ Ebuyer)
Motherboard: MSI H270 TOMAHAWK ARCTIC ATX LGA1151 Motherboard  (£116.80 @ Alza)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (£105.59 @ Aria PC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£89.00 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£64.41 @ Ebuyer)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  (£377.94 @ More Computers)
Case: NZXT S340 (White) ATX Mid Tower Case  (£59.91 @ Ebuyer)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£64.80 @ Alza)
Monitor: Asus VG248QE 24.0" 1920x1080 144Hz Monitor  (£234.99 @ Ebuyer)
Total: £1418.28
Generated by PCPartPicker 2017-03-03 14:17 GMT+0000
https://linustechtips.com/topic/746771-first-build/#findComment-9458318
Thanks though
For what is worth you pay for the key not the install media, also use pcpartpicker.
Could you avoid quoting gigantic posts for the sake of leaving the thread clean? -snip- it if possible
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/746771-first-build/#findComment-9458320
CPU: AMD RYZEN 7 1700 3.0GHz 8-Core Processor  (£304.90 @ Alza)
CPU Cooler: Enermax ETS-T40F-TB 47.7 CFM CPU Cooler  (£36.60 @ Amazon UK) contact enermax for am4 mounts.
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  (£103.62 @ More Computers)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£66.52 @ Amazon UK)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Video Card: Inno3D GeForce GTX 1080 8GB Twin X2 Video Card  (£475.99 @ Scan.co.uk)
Case: Cooler Master MasterBox 5 (White) ATX Mid Tower Case  (£49.98 @ Amazon UK)
Power Supply: Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  (£64.99 @ Amazon UK)
Monitor: AOC G2460PF 24.0" 1920x1080 144Hz Monitor  (£229.98 @ PC World Business)
Other: Asrock X370 killer SLI (£136.90)
Total: £1505.42
Generated by PCPartPicker 2017-03-03 15:23 GMT+0000
Edited by herman mcpootis
https://linustechtips.com/topic/746771-first-build/#findComment-9458340
Just now, tinyman1199 said:
PCPartPicker says: "be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler and AMD RYZEN 7 1700 3.0GHz 8-Core Processor are not compatible"
be quiet has announced that they will offer free am4 mounts to buyers of the dark rock 3.
http://www.bequiet.com/en/am4
https://linustechtips.com/topic/746771-first-build/#findComment-9458350
25 minutes ago, tinyman1199 said:
oh okay thanks.
I prefer the first build that was commented anyway
the ryzen 7's 8 cores will be much better over the i7 when you use it for rendering youtube videos. you also get SLI support and a much better cooler for overclocking with the build i made.
https://linustechtips.com/topic/746771-first-build/#findComment-9458405
