you can throw as many cores as you can get at vray,or if he's using the vray rt engine (maybe ask him) get some gpu's for that
edit: to answer the question,yes vray will benefit highly from more cores
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
4 hours ago, Ethocreeper said:
new amd server gpus are coming so if you have the money wait and get those else get a ryzen 7. and try to use gpus if your current system supports them (probably it will support 2). also use a quadro. they are made for these jobs
Do I have to take vray rt for using gpus, cause vray rt doesn't have the full feature set as compares to advanced
Please quote me so that I know that you have replied unless it is my own topic.
yes you have and just to make your life easier lots of features exist like lighting but as i found it you need to make it very bright to show up. btw be sure to use vray rt production renderer and have cuda enabled if you have nvidea
