CPU cooler for Mini-ITX
Go to solution Solved by Mr.Meerkat,
57 minutes ago, IAmLastPrime said:
I am worry about CPU temperature.
For the pentium? Nawh, the stock cooler will cool it perfectly fine :)
The only time the stock cooler would struggle cooling a CPU is when you overclock an unlocked CPU ;)
20 minutes ago, IAmLastPrime said:
What about T2 mini?
Still too tall. Though I typod max height, it's 96mm if you use normal ATX PSU. If you get SFX PSU with Silverstone bracket (http://silverstonetek.com/product.php?area=en&pid=631) you could add maybe 10-12mm to that limit (approximation based on pics). In which case T2 mini might fit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9439866
Thank you for answer my silly question. xD
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9443452
36 minutes ago, IAmLastPrime said:
I am planning to build Mini-ITX PC for gaming. I need some suggestion about which CPU cooler is the best and value for Mini-ITX. Case : Cooler Master Elite 110.
Depends. I had an Elite 110 case with an i3-6100 and a GTX 750 Ti that used a Cryorig C7, a Zalman CNPS7000(V)-AL, and ultimately the stock cooler without any issues (including noise). When I switched out the i3 for an Athlon 5350 and took out the GPU, it didn't even need the front fan installed. Just sat there running silently with perfectly sane temperatures.
If you're just tossing a cool, locked down CPU in there, I'd save the money and run with stock. If you're trying to overclock, I recommend a different case.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9444181
16 hours ago, IAmLastPrime said:
Any other suggestion?
What cpu are you cooling?
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9450046
8 hours ago, IAmLastPrime said:
Intel Pentium G4560 in Cooler Master Elite 110 for gaming
Why not just use the stock cooler?
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9454085
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9468758
Thanks for your answer.
https://linustechtips.com/topic/745502-cpu-cooler-for-mini-itx/#findComment-9478478
