top kek
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9434811
1 minute ago, grimfaced001 said:
I already have a modem that connect to the router, which is in a far room, and what i would like to try to do is to split the coax signal so it still connects to the modem and router, and have it run over to my PC
run ethernet or get another modem(not sure if this works you have to ask you cable provider)
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9434831
your two options are a) pay for service to a second modem from your cable company, or b) get a pair of MoCA adaptors. MoCA is like powerline except over coax.
2 hours ago, SammYw0w said:
If you want to use your coax cable to run ethernet to your PC for example ypu're going to need one of these: https://www.bhphotovideo.com/c/product/1172333-REG/actiontec_ecb2500c02_ecb2500c_moca_ethernet_to.html It supports up to 175 Mbit/s speeds.
This is a good example of a MoCA adaptor, and frankly is the only model that is easy to find for sale.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9435533
yea would probably be more cost effective to just run an ethernet to the new computer and you would probably have less latency
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9435748
i was thinking my self just recently to do something similar with the top of the line actiontec adapters
First PC Build
CPU: i5 4690k  (4.7Ghz 1.36v)                                        MOBO: MSI z97 gaming 5
GPU: MSI GTX 1070 gaming x                  Case: NZXT s340 elite Black/Red
Storage: 1tb seagate SSHD, 240gb PNY ssd                    PSU: Corsair RM750X
Cooling:H100i V2 / Bequiet Fans
16GB Hyper X Fury Memory
Benched on CPUZ (Single-thread=2140) (Multi-Thread=8316)
Fire Strike 1.1=13660
Time Spy=5519
Cinebench R15 (CPU= 509cb) (OpenGL=118.28 FPS)
Unigine (Superposition 4k optimized=5581) (Heaven Extreme=120.6 FPS Score:3038) (Valley Extreme HD= 92.7 FPS Score:3879)
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9437387
10 hours ago, grimfaced001 said:
Is there anyway to convert a coax cable to ethernet cable so I can connect it to my PC?
What you want are MOCA 2.0 adapters. The easy thing about them, there only made by Actiontec. Im not sure when, but they are releasing updated version of MOCA that can do faster speeds. Just need to make sure if that coax is used by your cable company that you have a MOCA filter on the line and MOCA compatible spliters. Make sure the run end to end is no more than 300 feet as any further can cause issues.
https://linustechtips.com/topic/744703-coax-to-ethernet/#findComment-9437993
