10 hours ago, Robots (2005) said:
im looking for a small tv to have at the foot of my bed, like a cheap small one maybe 20 inches.
then im looking for a stick you plug in it that will let me steam shows and stuff, or one that can run popcorn time,
any price
I use a fire stick tv with Kodi it will let you watch ANYTHING
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9428680
One thing I like to say, most newer TV's have a composite/Component input jacks. So you can only hook one up at a time. As far as sticks goes, My dad has a Roku stick, seems to work well, he likes it. My sister has the Amazon Fire Stick with Kodi (With the "Unsupported Repositories"). I have Kodi installed on my computer, its good, but I do have a feeling the "Unsupported Repositories" cause it to run a little buggy at time.
As far as TV's go, at that size you will have to decided 720p and 1080p. I do know a lot of smaller TV's are still offered in 720p. Not a big deal, because at that size and viewing distance you probably wont notice anything. I would just make sure its LED back lit. My mom has a 19" Vizio, its cool because it has a front facing speaker, plus it was pretty cheap. I tend to say Samsung, LG, or Vizio if you want cheap. Ive also noticed TCL, who has Roku functions built in to the TV. Not sure about TCL as a brand though, they are a Chinese company, and I do know they make an American brand, just cant remember which.
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9429608
Never said budget said small lol. This guy
Hey, don't blame me for your typos, lol. This guy...
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9432954
any price
For the stick you can check eBay for Android sticks. Allow you to install Kodi which can be used as a media centre for streaming TVs locally and over the internet.
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9432961
5 minutes ago, Robots (2005) said:
what it ment is like a cheap one but better, thats why i said like
What would you consider cheap?
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9432994
1 minute ago, Robots (2005) said:
like basic no smart features and stuff
I mean price wise. I should of made that clear. To me a cheap TV would be under £100 or $120
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9433002
Can we have a currency or location because without that you will be getting cheap TVs in different currencies.
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9433024
34 minutes ago, Robots (2005) said:
usd
VIZIO D24hn-D1 D-Series 24" Class LED TV (Black) $117
Its a 24" but the only 20" screens i could find were monitors.
https://linustechtips.com/topic/743973-tv-and-stick/#findComment-9433098
