Help with Noise
Go to solution Solved by WoodenMarker,
You reckon the CPU cooler is the issue then?
The stock intel cooler isn't actually that loud normally.
Try to figure out what fan is loud before deciding on getting anything.
Just manually stop the fan with your hand one at a time to isolate which is the loud component.
What case do you have? Pretty sure your gpu is not the problem. If your cpu fan is loud, your case probably just has bad airflow or you haven't adjusted the speeds in the bios.
Btw, you can set a custom gpu fan curve with msi afterburner and make it pretty much silent.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Hi,
I'm running a Mini-ITX system, and the temperatures are great (30 C in idle now and mid 65 during constant 100% loads). The issue is these temperatures are clearly achieved by the cheese grater side panels, and noise is a bit of an issue, as the computer is next to me on my desk.
I want look into improving this, but I'm unsure what's responsible for the noise, my hardware is as follows:
  • CPU : Stock Intel heat sink (Nothing bigger will fit in this case
  • GPU: Asus DirectCU II (GTX 760, right next to the cases side panel vent)
  • case fans : 2 stock fans, 1x120mm, 1x80mm(15mm thick, so no quality replacements)
As far as I can tell, I could do the following
  • Get a new case with less vents (some money)
  • Get a new CPU cooler, requires a different case (lots of money)
  • buy case fans (cheap, not sure it's the problem)
  • unplug/remove 80mm fan (free, not sure it's the problem)
So, does anybody have a good idea what the weak links are in terms of noise in my computer?
https://linustechtips.com/topic/74349-help-with-noise/
This would be quiet: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23&products_id=21828
If you not worried about looks, then fill the case up with noctua fans,
Could be your psu as well, what make/model is it?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1018953
Get a Samuel 13, low profile CPU cooler but you have to get a fan for it.
It doesn't seem to be sold anywhere in the UK, and it looks like it would definitely cause RAM or other clearance issues.  :(
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1018954
I did look at that, but for a 77W processor Noctua recommend to disable turbo mode
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1018969
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1018972
Yeah, it was the 80mm fan giving out a significant whining noise, Shame on me for not checking.
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1019033
What CPU do you have, do you have a bower style gpu and whats your psu?
Don't worry then lol
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1019066
If you want to replace it: http://uk.pcpartpicker.com/part/noctua-case-fan-nfr81800
If you don't want to spend so much on a fan: http://uk.pcpartpicker.com/part/arctic-cooling-case-fan-afaco080pcgba01
Both are really quiet and move a good amount of air.
https://linustechtips.com/topic/74349-help-with-noise/#findComment-1020099
