well if you have an nvidia card you could use shadowplay, you have to download geforce experience though.
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417244
Yes both nvidia and AMD provide capture software that doesn't chip away in your frames. No matter what brand you choose :)
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417246
NVidia has, as mentioned by other already, Shadowplay.
Shadowplay is avaliable through Gefore Experience and is free and easy to use.
Any capturing software will nibble more or less on your frames but I believe shadowplay shows mercy on that part. :)
EDIT:
Welcome to the forums!
If you want people to see your answers, make sure to quote us. You do it by pressing the small arrow under the comments!
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417290
as I said. toggling shadowplay on my gtx 1070 and a i5 3570k makes the difference between 150 and 130 fps in overwatch
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417295
13 minutes ago, Ruffleduffle said:
And? where is the problem? If you have a nvidea card use shadowplay and if you have amd graphics, just use plays.tv
It's called ReLive now and is different and far superior
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417306
21 minutes ago, Ruffleduffle said:
I dont know about amd's tech but shadowplay does nibble a bit on your frames, not much tho
I believe amd has raptr or plays tv. One of the 2
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417350
2 minutes ago, TheRandomness said:
-Thread moved to Graphics Cards.
They dropped support for both and now they have ReLive.
Ah ok thx for the heads up. Been a while since I used my last radeon card :)
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/743037-help-me-ples/#findComment-9417361
