Computer using 2/3 of system RAM at startup
Solved by Mira Yurizaki,
1 minute ago, ZachTheDoge said:You are correct; the list is sorted by most memory usage. Here's the memory section http://prntscr.com/ec80lg
Bingo, your Non Paged Pool is through the roof.
This is usually an indication of a driver problem, and usually when I see this problem it's the network driver. I would suggest updating that or roll back to a previous version if you're at the latest version already.
If that doesn't work I can go dig around for other possibilities.
