Good afternoon,
I am looking at building my own PC (first timer) and was wondering if you guys could put something together for me using the UK PCPartPicker.
Requirements:
  • I ideally need two monitors as I'll be doing work from home and I am so used to two that only one would be a pain
  • I am looking at starting gaming on the PC but this isn't a massive concern at present (the ability to upgrade would be helpful though)
  • I currently use my laptop for the following:
    • Sublime
    • Microsoft Office
    • Football Manager 2017
    • Web browsing, YouTube and the sorts
  • Budget isn't massive but possibly around £750 if possible. I know that the monitors don't help here :(
Any help and advice would be massive and fully appreciated. Thanks in advance. If I've left anything out, please let me know!
https://linustechtips.com/topic/741460-new-build-help-please/
Something like this
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (£281.94 @ Aria PC)
Motherboard: MSI B150 PC Mate ATX LGA1151 Motherboard  (£79.87 @ CCL Computers)
Memory: ADATA XPG Z1 8GB (2 x 4GB) DDR4-2133 Memory  (£44.15 @ Amazon UK)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  (£39.47 @ Amazon UK)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Video Card: MSI Radeon RX 480 8GB ARMOR 8G OC Video Card  (£199.98 @ Novatech)
Case: Thermaltake Versa H23  ATX Mid Tower Case  (£26.48 @ Aria PC)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.98 @ Ebuyer)
Total: £757.81
Generated by PCPartPicker 2017-02-21 13:40 GMT+0000
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399247
Yep, dual monitor + decent machine with 750 pounds is gonna have to massively sacrifice something.
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399248
1 minute ago, deXxterlab97 said:
Something like this
Total: £757.81
You are missing the 2 monitors that @captainClueless wants.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399252
Thanks. I thought it was out of budget
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£185.00 @ Amazon UK)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (£45.99 @ Amazon UK)
Memory: Team Elite 8GB (1 x 8GB) DDR4-2133 Memory  (£47.79 @ Amazon UK)
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card  (£169.98 @ Novatech)
Monitor: Samsung S22D300HY 21.5" 1920x1080 60Hz Monitor  (£84.98 @ CCL Computers)
Total: £731.12
Generated by PCPartPicker 2017-02-21 13:43 GMT+0000
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399261
Total: £731.12
Wow, You can do magic in no time!
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399275
Total: £731.12
good but as its still in the budget i would go for 7th gen build
PCPartPicker part list: https://uk.pcpartpicker.com/list/XmT9XH
Price breakdown by merchant: https://uk.pcpartpicker.com/list/XmT9XH/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  (£187.99 @ Aria PC)
Motherboard: MSI B250M PRO-VDH Micro ATX LGA1151 Motherboard  (£65.91 @ Ebuyer)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR4-2400 Memory  (£47.95 @ Amazon UK)
Total: £754.19
Generated by PCPartPicker 2017-02-21 13:52 GMT+0000
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399315
Total: £754.19
For a very small performance increase?
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399326
3 minutes ago, Hunter06 said:
h110 mobos are crap and yes 20 bucks more for slightly faster processor, better mobo and a faster ram is worth it
He can OC the Ram. The 200 Mhz difference is going to make minimal difference, OCing his RAM and saving his money will offer a higher increase in performance and H110 mobo's aren't meant to be good. Neither are B250/B150 boards. Fuck, they're supposed to be lower end than H boards last I checked, just recently have manufactures decided to start making them look like their Z series counterparts. Anyways, the difference between the fuck ton of low end boards is marginal. Minor differences here and there that unless you're looking for a specific thing, no need to do it. Spend that 25 pounds on a nice game.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399346
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor  (£168.59 @ Aria PC)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (£45.99 @ Amazon UK) find out if the bios supports kabylake.
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified ATX Power Supply  (£44.98 @ Ebuyer)
Monitor: AOC G2260VWQ6 21.5" 1920x1080 75Hz Monitor  (£100.62 @ Aria PC) main monitor, swap it to another samsung if you dont't mind not having freesync and higher refresh rate.
Total: £764.98
Generated by PCPartPicker 2017-02-21 14:08 GMT+0000
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9399357
Thanks everyone for the input, it's massively appreciated. Just wondering what people think of this too:
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard  (£65.06 @ Ebuyer)
Memory: Kingston HyperX Fury Black 4GB (1 x 4GB) DDR4-2133 Memory  (£23.59 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 1050 Ti 4GB Windforce OC Video Card  (£149.36 @ Novatech)
Case: Zalman ZM-T4 MicroATX Mini Tower Case  (£28.95 @ Amazon UK)
Total: £715.02
Generated by PCPartPicker 2017-02-22 13:54 GMT+0000
https://linustechtips.com/topic/741460-new-build-help-please/#findComment-9404949
