Hey so i build my first computer a few days ago and its been working fine while playing games and stuff but some times when i alt+tab between stuff or even open a browser i get these wierd color problems it changes back to normal if i scroll the page or sometimes even when i put my mouse over it.
pic: http://img577.imageshack.us/img577/562/aubo.jpg
Thinking its something wrong with my gpu. I have the latest drivers for it tho and its been working fine while gaming so thats wierd.
My specs are:
cpu: FX-8350 @4ghz
mobo: crosshair v formula-z bios version 1602
ram: g.skill sniper 1866hz 2x4gb
psu: corsair hx750
gpu: sapphire r9 280x vapor-x @stock
windows 8 64bit
https://linustechtips.com/topic/74121-display-problem-with-my-first-build/
I had a similar sort of problem with my gpu. Turned out to be a driver out of date. Double check that you have the latest drivers installed first. If not check overdrive to make sure your gpu isn't throttling. Shouldn't be if you're just on browsers but could be a cause. Other cause could be your hdmi/input cable. If none of these then I'd contact amd
