Hey, So if I was to buy a new motherboard will it need to be the same chipset as the old one because someone said my CPU only fits one chipset, My CPU is a i5 quad core 3.ghz with a 1155 socket. Now obviously I need the same socket on a new motherboard but does the chipset have to be the same as my old chipset (h61)
Thanks
https://linustechtips.com/topic/74079-new-motherboard-help/
Is this a unlocked processor? so like a 2500k, 3570k? Or?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/74079-new-motherboard-help/#findComment-1014884
if u can go z77 for sure
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/74079-new-motherboard-help/#findComment-1014886
I'd go z68 if you have a sandy-bridge processor and z77 if ivy-bridge. But if the budget is there maybe z77 all the way...  It does depend on your processor and your budget so a little more info would be nice =)
Yarrrr, ye be warned lily-livered scallywags
https://www.youtube.com/watch?v=SLMJpHihykI#t=93
https://linustechtips.com/topic/74079-new-motherboard-help/#findComment-1014902
Right so If I go this http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&tool=3 and my old one was this http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000554 would I need a new copy of windows and if not how would I got about installing etc.
https://linustechtips.com/topic/74079-new-motherboard-help/#findComment-1014986
If it is an OEM copy you would need a new copy as the copy is tied to your motherboard but some people reported that it works. If yours is not an OEM copy, you would have to activate windows through Phone activation or uninstall the key and activate it on the new computer:
Windows 7:http://www.sevenforums.com/tutorials/18715-activate-windows-7-phone.html
Windows 8: http://www.eightforums.com/tutorials/24636-activate-windows-8-phone.html
Link in uninstalling key:http://www.howtogeek.com/124286/how-to-uninstall-your-windows-product-key-before-you-sell-your-pc/
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/74079-new-motherboard-help/#findComment-1018659
