hi all im new here and i need know what is the max voltage cache for my i7 4790k cpu? because i have this at 4.6ghz OC with 45x cache ratio multiplier at 1.29v and i found stability but i have read that cache voltage should not go beyond that 1.15v (strange, but by default this is at 1.185v 40x cache ratio) and i have mine at 1.29v. that for im worried. my motherboard is an z97a.
https://linustechtips.com/topic/740207-i7-4790k-help/
2 hours ago, ppdemo said:
yes i know about vcore, but my questions is about cache voltage or also calles Vring
Was the cache ratio unstable at any lower voltages than 1.29 or was that not tested? Usually you won't notice any improvements anyway from cache overclocking but yes you don't really want to approach 1.3v (on cache) for extended periods of time (ideally not passing 1.2v if not doing anything hardcore). I was confused because you basically said the Vcore is set to the same voltage as the Cache which there is really no need for that, cache should be stable at much lower voltages.
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9387171
more stable i test is 1.260 but it seem to high still, i remember that by default motherboard show me 1.185v cache voltage 40x cache ratio multiplier.
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9388736
I would just set it at 1.2 and see how high much higher  you can get it over stock.
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9389269
Mine stays at 4700 when ever in use. 1.26 normally.
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9414473
My cache voltage is set to 1.192v, my cache ratio is set to x43
My understanding of the Cache Ratio settings on haswell needs to be within 3 of the CPU Multiplier (mine 43 and 46) to maintain stability.
When i first got my chip i had all kinds of problems with stability because i hadn't got enough voltage going to the cache and the ratio was set too low.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9414719
der8auer wrote a devils canyon overclocking guide (here) and according to that, 1.15v is safe for 24/7 use and 1.25v is safe for "testing".  The table with the voltages is close to the bottom of the page.  The whole thing is worth reading if you've got the time though
edit: i've been using 1.25 for a while now, but i like to live dangerously  ^_^
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/740207-i7-4790k-help/#findComment-9414819
