Ryzen Build Plan
On 2/18/2017 at 7:17 AM, SCAMAZING said:So I'm thinking of doing an AMD Ryzen build when it comes out. The CPU is the R5 1500. The MOBO is undecided due to no selection (yet)
The rest of the system is:
PCPartPicker part list: https://pcpartpicker.com/list/xLpQM8
Price breakdown by merchant: https://pcpartpicker.com/list/xLpQM8/by_merchant/CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($129.97 @ Amazon)
Storage: OCZ TRION 150 480GB 2.5" Solid State Drive ($129.88 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($88.88 @ Newegg Marketplace)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card ($580.00 @ Amazon)
Case: BitFenix Prodigy M Arctic White MicroATX Mini Tower Case ($75.99 @ NCIX US)
Power Supply: EVGA SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ B&H)
Total: $1124.70
Generated by PCPartPicker 2017-02-18 09:14 EST-0500
So is this good for Ryzen?
The parts should be fine, no matter whether you end up with an Intel or AMD platform, as the parts should work with both just fine with no issues. If you're sticking with one GPU, the PSU will be fine as well.
