Yes. And for reference, please use the Clevo tags, P870KM1 and P870DM3. It's just alot easier when discussing Clevo laptops because Sager brands them differently, origin brands them differently, myth brands them as the phobos, and basically there's too many names.
And never buy from Origin LOL. Not laptops anyway. There is literally 0 reason to get it from them. 0. I literally challenge someone to find a reason. It's overpriced to hell, doesn't have the proper bios, you can get cheaper, better parts, better support elsewhere.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/739875-help-laptop/#findComment-9383446
Thanks again
https://linustechtips.com/topic/739875-help-laptop/#findComment-9383645
