Recently, my phone has started acting up and it is really irritating.
I have a Nexus 5X and the WiFi stopped detecting my network, and when it does, it can't connect.
What I mean by that is the Router and other devices are saying the Wireless router part is working. But the phone refuses to connect. I'll try to attach a screencap.
If I do, CalamityNet is the network in question.
I have already tried rebooting the router and everything. Yes, the network is mine. So is Marshall, which is irritating because Marshall is the router/modem that the Netgear (CalamityNet) is connected to.
Marshall is slow as all hell, so I do not want to use it.
nexus.mp4
The Screen is yellow because I use f.lux
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/
try turning the phone off, into you're recovery and resetting the cache
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382496
Will do. Plus on another topic, it says it's a pixel from when I "modded" google assistant in, although I thought I undid my changes
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382500
we've all done that mod :) i had the same on my old n4, a cache reset was all it took. All of them (cache, davlik & ART)
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382504
I'll have to reboot into recovery again, but it seems to have worked
good!
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382510
Thanks a lot for helping. This is optional to answer but do you know why that happened?
i think mine did it because it decided to. my phone was tempremental. it didnt do it after that.
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382525
and you welcome!
https://linustechtips.com/topic/739795-nexus-5x-wifi-problems/#findComment-9382527
