PC sub-par performance, crashes, fresh hardware.
Heyo o/
One of my buddies recently got a new pc with all fresh parts. (A couple of weeks ago).
They are as followes:
MB: MSI H110M PRO-D
CPU: i5 6600k
RAM: 8gb of something
GPU: GTX 1060
PSU: Corsair VS450 V2
SSD: OCZ Trion 150: 120GB
So he's been struggling with general high CPU usage in idle / browsing. Slow browsing, games crashing and while in League of Legends specifically he can not load certain web-pages like a Mobafire Champion build-page.
He's installed a fresh windows 10 64bit several times. I've even given him an install that I've been using without problems, and that brings the same issues.
I've not had the oppertunity to be hands on with his PC other than with Teamviewer. And for that reason it's hard for me to really know what's going on with all of the latency and not to mention the fact that I can't access bios or anything.
Here's what he's tried so far:
As mentioned, reisntalling windows 10 multiple times.
Installing fresh drivers, one for one, from manufactures sites. (Like chipset drivers, grafics and so on.).
He has been using this benchmark that I'm not familiar with, but I'll post some photos anyway for you to look at:
Thanks for any input! :)
Everyone have a cool signature. I don't, so I thought I would write something.
- Cool right?
Have you run a memory test? Memory is a common source of instability.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
well it seems memory is running above expected but cpu and gpu are running below.
I would have it's either a driver or a hardware problem.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
11 minutes ago, XzzDSA said:
Heyo o/
MB: MSI H110M PRO-D
CPU: i5 6600k
GPU: GTX 1060
Tell your friend he's made an incorrect choice of mobo. He has a 'k' series CPU (A CPU that has overclocking) and a 'H' series motherboard, a motherboard without overclocking. The potential of the 6600k is being wasted
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
It's not, it runs quicker than 6600 locked probably. Doesn't really matter, everybody makes stupid decisions.
idk
Stupidity: doing the same thing over and over and expecting different result
If you do it twice and it doesn't work, change tactics. There is clearly nothing wrong with the software part. One of the components is causing crashes and poor preformance.
Do as the Doroidbot says, this guy's the shit! He's helped me on multiple occasions and is usually right about what he says.
  • 3 weeks later...
On 17/2/2017 at 0:00 AM, Droidbot said:
Download Memtest onto a flash drive and run it on the machine overnight.
Right, I'll tell him this.
First of all, it's "Insanity".
Second, my friend is not very 'educated' on the details of how a PC works. So the chance of him installing something that he shouldn't have, or using a, somehow, corrupt windows installation, is rather high. This is the reasoning for trying to install windows several times, different versions. To try and uncover wether or not that would've brought any problems.
Btw. When first joining a discussion, maybe you should consider to not call someone 'stupid' as the first thing. Just a suggestion m8 ;) Someone might actually get offended.
Anywho. Sorry for not being active and replying to all of your reply's. I've suspected the memory of being the problem aswell, but we had it running in prime95 for a few minutes so I didn't really think more of it (obviously this is not a genuine stability test methodology).
A little update on the situation though. It for some reason ran fine, after I posted this thread, up until today, hence I've not been active here.
So I'm going to suggest my friend, what @BlueChinchillaEatingDorito and @Droidbot suggested, and run memtest overnight and see if that reveals anything. - Just to be sure, we're talking this program: http://www.memtest86.com/, right?
Thanks guys o/
- Cool right?
