hi.  sometimes my computer kinda has hiccups in where it will just take absolutely for ever to load something and then other times its really fast. any ideas?
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/739135-computer-running-slowley/
Is it the SSD that has mood swings or the HDD? If it's the SSD, change it ASAP. if HDD, do a fregmentation on it. If nothing changes, run SMART on it. If smart shows bad sectors, change the disc.
Most importantly, do something about it. If my computer acts just a bit out of his usual self, I check everything. And I mean it.
Take into account your disc age and how much you use it, do you turn your computer on and off often, that kind of stuff.
https://linustechtips.com/topic/739135-computer-running-slowley/#findComment-9376117
If you're running Windows 8 and above, open task manager and go to the performance. Monitor which component is being utilized as those hiccups occur. From personal experience, it's most likely the HDD just being slow as old balls. If it's not the disk, the problem is somewhere else like an infection.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/739135-computer-running-slowley/#findComment-9376157
sometimes its just windows. I've seen my windows 10 refuse to open one folder on my drive, crash, restart and then be fine.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/739135-computer-running-slowley/#findComment-9376208
Is it literally BSOD kind of crashing or is just Windows Explorer not responding, then restarting the process not the entire system?
https://linustechtips.com/topic/739135-computer-running-slowley/#findComment-9376216
i use google chrome.  its on my ssd which is a 850 evo.  it just happenes every once in a while not all the time
https://linustechtips.com/topic/739135-computer-running-slowley/#findComment-9376291
