Hi there,
i want to know which lenses LTT uses.
I aleady found this out:
Canon 24-105 f4 L (in older Videos)
Tamron 24-70 f2.8
Sigma 50mm f1.4 Art
I know that there is one more in Black/Red, manually, something like Samyang ? (Probably now replaced by the Sigma)
Also there must be a few other ones.
Thanks for help
https://linustechtips.com/topic/738633-ltt-camera-lenses/
I'd personally just recommend PMing/tweeting Brandon on twitter or something like that :P
We  don't really know any more than you as we only have the same sources of information as you do so...
On a side note, why do you need to know what lens they use anyway? I mean if you're looking for a lens for you to use then just copying LMG isn't a great idea as the choice of a lens should be based on the situation (low light? Focal length? ect.), your usage, your opinions/needs/wants, budget (ect.) on a lens so...
I'll tag @nicklmg anyway as he works at LMG so...maybe he could help :)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/738633-ltt-camera-lenses/#findComment-9370595
1 minute ago, Bouzoo said:
So does @BRollTheIntern :P who is probably never online
Yeah, Nick is like the only person who's actively online on LTT forums :P (ignoring @Slick, @TaranLMG who are sometimes online due to reasons...)
https://linustechtips.com/topic/738633-ltt-camera-lenses/#findComment-9370682
fairly sure they have used the sigma 18-35 1.8 a bit
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/738633-ltt-camera-lenses/#findComment-9371138
