1 minute ago, Ahoy Hoy said:
So I got a arduino mega being used with some laser distance measures and a gyroscope to tell a position of a drone.
I want to send this data back to a computer. I need to send 6 distance data and 6 gyroscope data. So 12 numbers in total.
How could I do this?
The simplest solution would be to get a cheap set of RX and TX modules and send everything through a serial com port. The best solution IMHO however, is to get am set of NRF24 transceivers. Those allow for much more flexibility, reliability and range. Plus they already have an arduino library which very well documented and maintained.
Cheers!
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
Cheers!
How would I take the receivers output into the computer?
With either another arduino or a SPI bus decoder
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
Right ill get another arduino, whats the cheapest smallest one which could handle it.
Also something like this for the transmitters and receivers http://www.robotshop.com/uk/2-4g-wireless-module-w-pa-lna.html
Holy Molly is that expensive! I feel for you living in such a taxed country. Anyway, any arduino should be more than enough since they all have hardware support for both SPI and Serial.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
Right ill get a uno since I wanted one anyway and there basicaly the cheapest.
I would advise you to use a a HC-05 Bluetooth module to connect to your wirelessly. I would advise you the HC-05 than RF transmitter/receiver because it is really really  easy to use. Plus you are using Bluetooth(You can connect to your laptop tablet or smartphone).
Here is the data sheet
http://cdn.makezine.com/uploads/2014/03/hc_hc-05-user-instructions-bluetooth.pdf
Soham Bhattacharya
operatingsystems.co.in
Soham Bhattacharya
Bluetooth is very short range, has a lot of latency, is less flexible and requires a master-slave configuration, and on top of that is has large packet transfer protocols. Not very suitable for this application in particular.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
