CPU COOLER
Solved by GreenToxon,
If you aren't overclocking, you would be wasting money purchasing a bigger aftermarket cooler for performance.
Now, if you do plan to upgrade your MoBo later you should save that money that you would be spending on the cooler for either a better MoBo or whenever the cooler you like goes on a crazy good sale.
If you don't like how it looks, that's also another reason for getting a cooler and you should get that CM V8 GTS.
