For my first PC build i have been recommended to do an AIO cooler by very many people, but I have also gotten people who say that air will do just fine as long as i dont mind about size/ looks as much. I am going for a black box computer so looks have no meaning to me. I do not foresee myself overclocking a huge amount (I will be going with a i7 7700k). I strictly want to know 1. How much more performance will i get out of an AIO vs an Air cooler and 2. What is a solid Air cooler in the $50-$70 price range. (The AIO i was looking at was the H100i v2)
https://linustechtips.com/topic/738094-air-vs-liquid/
Unless you have a 10-core CPU you will not get better performance. water cooling can only outperform an air cooler if the surface area of the radiator is greater than what you can get with an air cooler. Look for the sandwich design, the phanteks cooler might be in that price range
http://www.phanteks.com/PH-TC14PE.html
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9364616
Cooler master hyper 212 evo is one of the best coolers, and it's quite cheap.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9364632
And a little too weak for an overclock 7700k. It can't keep up with my 8c Xeon even at 2.6GHz.
Laptop: Asus GA502DU
RAM: 16GB DDR4 | CPU: Ryzen 3750H | GPU: GTX 1660ti
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9364762
What kind of temps are you getting and have you tried reseating your cooler? The 212 Evo should be plenty for a e5-2670.
@theminnesotanman Where are you shopping/located?
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365086
Yeah reseated and replaced the thermal compound. Idles around 50C, at the moment I have about 6 tabs in Chrome, a download and a Youtube video and I'm at 59 degrees. I do have the BCLK at 107, but I'm at like 1.12V. Max I've seen is up to 70 degrees.
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365099
That's plenty of thermal headroom--I don't see the problem?
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365105
It should really idle in the mid 40's, and I did come from an FX 8320 @4.2GHz, so anything above 60ish seems really hot to me.
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365109
It may be due to the oc. Does reverting the settings to stock lower your idle temps?
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365111
I've actually never tried :P It's running at very slightly lower voltage than stock. Meh, if you say it's fine it probably is. I'm just used to things running much cooler.
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9365117
31 minutes ago, theminnesotanman said:
@WoodenMarker I live in the US. I have a microcenter close by but i would prefer to buy online. I just wants a solid cooler for a decent price.
Depending on how much you want to spend, the best value coolers are probably:
PR Slim: http://pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
Kotetsu: http://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
Fuma: https://www.amazon.com/Scythe-SCNJ-4000-Ninja-Cooler-Heatsink/dp/B017S3ZJNY/ref=sr_1_sc_1?ie=UTF8&qid=1487134813&sr=8-1-spell&keywords=scyteh+fuma
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9366849
1 minute ago, theminnesotanman said:
@WoodenMarker  So all of those only come with one fan. Will that provide enough cooling or would adding another fan help?
Adding another fan won't make much of a difference unless it's to make up for lack of airflow at very low rpms.
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9366897
So basically get this and some low profile ram and i should be fine? @WoodenMarker
What is 'this' referring to?
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9366907
2 hours ago, theminnesotanman said:
Im sorry. I was referring to the Scythe cooler.
Both the Kotetsu and Fuma are from Scythe.
The Kotetsu should clear the dimm slots completely and the Fuma should allow for slightly taller than standard profile.
http://www.pcgameware.co.uk/reviews/cpu-coolers/scythe-fuma-cpu-cooler-review/
https://linustechtips.com/topic/738094-air-vs-liquid/#findComment-9367268
