Looking for a pretty small mATX case, I'm thinking about getting the SGO2 case by silverstone... Any recommendations?
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
https://linustechtips.com/topic/73802-best-matx-case/
Fractal arc mini and 350D are WAY to big
https://linustechtips.com/topic/73802-best-matx-case/#findComment-1011271
How about a Bitfenix Prodigy M? Its pretty good for compact builds! Try it
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345031
Yea I thought about it... Still pretty big the SG02 and SG09 are pretty good and tiny
https://linustechtips.com/topic/73802-best-matx-case/#findComment-1011284
Wow so you want smaller than that :o But even the prod has a tuff time organizing dem wires...
Called short cable set xD
https://linustechtips.com/topic/73802-best-matx-case/#findComment-1011310
Sg09,Sg010 and theres a new case from aerocool dead silence cube looks pretty good coolermaster haf 915F/R thermaltake armor a30
What about the sg02?
https://linustechtips.com/topic/73802-best-matx-case/#findComment-1011395
