Hey guys
I have this external hard drive, and a few years ago it got a virus that made all the folders shortcuts. I knew a guy that said he could fix it, all we had to do was encrypt it with BitLocker. We tried to encrypt it, but the encryption failed at 5x%.
Then, everytime I plugged it to my PC, it would either give an error instantly or open a BitLocker window that said "Encryption in progress, 5x%". And after a few seconds it would close and give the same error.
Yesterday, I plugged the hard drive into a friend's computer, and after a while I couldn't access the hard drive. Turns out it had finished the encryption, somehow.
So, now, everytime I plugged it to my computer it asks for an encryption key, which I do not know of.
Question is, is there anyway to bypass that or something like it?
Thanks in advance.
EDIT: Well. Shit. I think all I can do is format the drive. No way to recover the data without the key. Fuck my life. Rip 700GB of photos
Edited by JoaoPRSousa
"an obvious supporter of privacy"
https://linustechtips.com/topic/737680-encrypted-hard-drive/
can you use a bootable usb containing a utility to visit the partition? you might be able to recover the data locked in the hard drive.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360379
Enlighten me please.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360405
there is a program that is a partition manager (forgot the exact name of it since its on my other pc) and you convert the iso to a bootable usb using rufus, then boot to the usb, and it should be a working program. from there, you can move partitions, you can resize them, you can delete them, hell i think you can even recover data from deleted partitions. but idk what all the features are since i only used the program to mark one of my primary partitions active.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360429
Well, all the data is encrypted. And I suppose that so is the partition. I'll try that tomorrow tho... :(
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360439
idk, since you run this program separate from windows, maybe you might be able to bypass the encryption. but idk i haven't tried the program with encrypted drives.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360458
Fuck.
Somebody please help me. I really really need to recover some of the files I had in the drive... :(
I found something on the MEMORY.DMP file with a disk decryption tool.
BitLocker Volume Master Key
Key data (hex): 8dbe296d5ce0f6c972a160a099a68b473ab9ffe9a9a250bd85cebf5fdfd8fef0
The thing is, this key has 64 characters and the keys BitLocker uses, if I'm not mistaken, have 48 characters. 6 groups of 8...
Please... :(
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360488
Fuck.
Please... :(
umm did u set up bitlocker on on windows 8+ with a microsoft account? if so, you might be able to find the recovery key in your account, according to microsoft support. https://support.microsoft.com/en-us/instantanswers/566e0e4e-4ca7-4df2-88fb-aa71c00ea55e/find-my-bitlocker-recovery-key
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360497
I think, when we did that, we did it on a Windows 7 computer... Not sure tho.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360512
well then that won't work. maybe try my method. download minitool partition wizard, use the iso, and "burn" it to a usb using rufus to turn it into a bootable usb, then just boot to the usb. don't worry, it has a GUI in case you can't navigate using commands.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360541
I will. Thanks.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9360558
That volume ID is useless. I will say it again, you cannot recover your data without the pre-shared key (password). Its like if I converted "hello" to "3455hb453" there is no way you will ever guess the original if I did not tell you the rules on how to get it back. That is encrption for you. Thats why we use it.
Quack 🦆
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9391765
Actually, when we encrypted the drive, we were using Windows 8, so maybe, the key is in my brother's account. Dunno, since it's an old account, I need to wait a few weeks to access it... We'll see. I really hope it's there.
https://linustechtips.com/topic/737680-encrypted-hard-drive/#findComment-9393986
