My buddy is giving me some parts to make a decent PC and it will be a major upgrade from my current PC...
I plan on playing Mobas and possibly WoW again... I'd like a duel monitor display but I could live without... I would rather not spend more then $500 er so but if something is worth then I understand the extra...
This is what I've got so far...
https://pcpartpicker.com/list/7kXgpb
https://linustechtips.com/topic/737248-help-my-first-real-pc-build/
4 minutes ago, Couzintony said:
Aw man, what sweet case!  Looks like a solid build though, maybe a larger ssd or a better GPU. Though you aren't paying for the 650 so...
Want to custom loop?  Ask me more if you are curious
Yea... I was thinking about a bigger ssd and I'm not too sure on which gpu I should get...
Do you have a monitor already?
Nope... but I'm not worried about those really... my wife would be pissed if i spent $1000 on the PC... n then need a monitor...Lolz
Suggestion?...
Edited by Couzintony
Grammer...
CPU: Intel Core i3-6100T 3.2GHz Dual-Core Processor  (Purchased For $0.00)
Motherboard: Asus H110M-C/CSM Micro ATX LGA1151 Motherboard  (Purchased For $0.00)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (Purchased For $0.00)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR4-2133 Memory  ($50.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($76.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($223.98 @ Newegg)
Case: DIYPC DIY-G3-R ATX Mid Tower Case  ($47.96 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Total: $499.24
Generated by PCPartPicker 2017-02-12 20:36 EST-0500
Suggestion?...
https://pcpartpicker.com/product/hqmxFT/aoc-monitor-g2260vwq6 has freesync for better smoothness with AMD gpus and 75hz.
Total: $499.24
Amazing!! Just what I was looking for...
1 minute ago, mcraftax said:
Few questions:
do you really need that case? just saying it would be a bit of a contrast to that parts inside.
would you be happy cutting a bit on the psu to get more performance? There are good ones for less.
do you know you need the 2nd stick of ram?
I would go for 250GB ssd if you can.
For a gpu, something like a gt1050 ti or rx 470
It looks pretty.... Lolz n it has rgb....... the only thing that lights up on my current PC is the power button... Lolz
I don't mind to cut anything for anything really... I was just kinda putting parts into pcpicker...
 Your list is solid.  I'd get a 4XX card and this monitor.  Sell the 650, get a 470 or 480, get Freesync.  You'd be golden :D
2 minutes ago, Couzintony said:
Thanks a lot!!! My buddy found another stick of ram for me so this is looking like the complete build as of now....
https://pcpartpicker.com/list/BWKyyf
This system will rock for mobas. upgrade to an i5 when you have the money in a few years time and you'll have a system for a good, long time
And at this point in time.... what would be a good CPU for an upgrade?... $200ish er so
i5 6500 or 7500.
i'd suggest this case over that S340. tempered glass.
https://pcpartpicker.com/product/H6L7YJ/phanteks-eclipse-p400-tempered-glass-atx-mid-tower-case-ph-ec416ptg_br
Here's the list with an i5 and Corsair 460x RGB
https://pcpartpicker.com/list/QqVssJ
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($196.43 @ OutletPC)
Case: Corsair Crystal 460X RGB ATX Mid Tower Case  ($139.99 @ B&H)
Monitor: AOC G2260VWQ6 21.5" 1920x1080 75Hz Monitor  ($119.99 @ Best Buy)
Total: $856.70
