Hello.
The plan for my setup was an X52 in the front with 2xFractal Design venturi HP-14 in push pull to get the best temps on the cpu but, then the question is do the Venturi's in the 120mm mounting way fit the rad?
For rear exhaust I was planning on using 1x 140mm Nzxt Aer and 2x140mm on top for mostly the rgb's.
The case I will be using is a Phanteks Enthoo Evolv.
Thanks in advance for your help.
https://linustechtips.com/topic/736675-need-help-configuring-my-fan-setup/
11 minutes ago, PrincipalFlash said:
Hello.
It standard comes with 140MM fans so I think it will fit
EDIT:
Ow I now read that you want push pull so then it gets bigger... I am not sure. Sorry :(
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
EDIT:
The X52 is the 240mm version. I think you are talking about the X62 which is the 280mm.
Not sure what the question here is. But I'll point out the obvious that 140mm fans won't fit to 2x120mm (240mm) rad. Since rad thickness is 30mm and fans are 25mm piece, you need to have 80mm clearance. If you have case already, that will be easy thing to measure.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
