CSGO Mouse going off screen HELP
Go to solution Solved by madsmuz,
Totally forgot I made this post, but I found my solution.
The problem was in Razer synapse, in the stats settings I turned the data tracking to off.
That fixed it for me.
I no longer have a Razer mouse but it could help someone else with the same problem :)
Hey everyone one, i have this wierd problem with my CS and my 2 screens. Check this video:
My specs: http://imgur.com/a/kdPAj
Settings Ingame: http://imgur.com/a/ylFik
I use 400 DPI and 2.0 SENS
Things i tried:
Formatted my PC
Close Razer Synapse
Changed resolution on my main screen
I hope someone can help!
TY
https://linustechtips.com/topic/736521-csgo-mouse-going-off-screen-help/
Well, if it's fullscreen your mouse should refrain within the bounds of that fullscreen application. Unless you're running some sort of software that overrides this.
Like borderless fullscreen applications.
Only program that i could thing of messing with my mouse is Razer Synpase, but i already tried closing that.
1 minute ago, elpiop said:
play windowed fullscreen. Or get something like this http://dualmonitortool.sourceforge.net/swapscreen.html to lock the cursor to the CSGO window.
I really want to play in 4:3 for the fps and gameplay wise. I dont really want to use a third party program but if thats my only way to fix it, i will try it.
It's funny how people who've never known CRT monitors want to play 4:3 all of a sudden. I could understand the older pro's being used to 4:3, but wtf.
I played with it since i started with CS, and im not really looking into to changing it. + 4:3 gives a huge fps boost wich also makes it easier to aim ingame.
tbh setting everything low already puts the complete load on the CPU. My fps is not determined by the GPU, so keeping it on native resolution helps with pixel-precise aiming.
Lower resolutions do actually make things physically bigger while reducing the FoV, can make it easier to shoot heads at distance. I do play at 1080p but I do certainly see the appeal and in the past i have played at a lower res.
@madsmuz I used to have this problem. It was because of razer synapse but you said you already turned that off so i'm not so sure. Make sure its completely off before you go in game. check processes in task manager to make sure there is no trace
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
  • 1 year later...
