Posted February 11, 2017 buying a new controller what's the best? Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 11, 2017 honestly I just got a 5 dollars generic usb gamepad that looks like ps2 controllers and I find it more than good enough was considering using my old x360 controller but the adapter was too expensive... took me a day to get used to it, and after adjusting sensitive on game it always serves fine. where I am going with this is that it probably hardly matters, both are great, if I had chose I would still pick microsoft because it is a tad more comfortable being bigger and all. Personal Desktop": CPU: Intel Core i7 10700K @5ghz |~| Cooling: bq! Dark Rock Pro 4 |~| MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot: SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro. Luna, the temporary Desktop: CPU: AMD R9 7950XT |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Aorus Master |~| RAM: 32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver) Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9347689 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 11, 2017 Prefer a Wired Xbox 360/One controller. Since I have big hands specifically. lttstore.com Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9347714 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 11, 2017 Depends on the games you play. If mostly steam, Xbox One controller. If retro, anything from 8bitdo that matches the console. Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9347736 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 11, 2017 Author it's for playing games like GTA 5 CoD zombies the occasional match of FIFA and Rocket league Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9347750 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 12, 2017 None of the above. The only controller I can stand to use is the Steam Controller. Playstation and Xbox controllers have their place, sure, but I don't understand how people can use them outside of a very specific set of genres. "Do as I say, not as I do." -Because you actually care if it makes sense. Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9352792 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2017 23 hours ago, Dash Lambda said: Playstation and Xbox controllers have their place, sure, but I don't understand how people can use them outside of a very specific set of genres. I'd say that about the Steam controller, personally. It's just a weird thing in between a controller and mouse control that, at the end of the day, can't either play games that are controller optimized for controllers as well as a controller with a traditional layout can because it lacks a D-pad and the button placement is really awkward (hitting the X button, for example, is like hitting pause on a Dreamcast pad because it's almost on the lower center of the controller...), not to mention the build quality is anything but confidence-inspiring, and it can't do mouse control as well as an actual mouse can either; it's literally the jack of all trades, master of none of controllers. Plus you have to go through an experience not much unlike the days of Xpadder to configure the thing. My personal recommendation would be to go with whichever layout between Xbox or PS you're most used to; those are the most solid traditional pads out there. My go-to pad is the Dualshock 4 since I'm most used to PS controllers, plus it has much more functionality than the Xbox pads thanks to programs like DS4Windows or InputMapper. Link to comment https://linustechtips.com/topic/736476-best-controller-for-pc-gaming/#findComment-9356487 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
