ive been thinking about buying a UPS but i have no idea what i would need for my system.
I7 6700k OC 4.2ghz
EVGA 1080 SC
Corsair Vegnance 3000mhz Ram
Corsair RM 750 PSU
Acer XB270HU monitor
normal Xfinity modem
Mainly looking for just enough time to shut down safely even if in the middle of gaming and one that has auto shut down in case im not around
i7 12700k/Asus Tuf z690/32GB Corsair Dominator RGB 3200MHZ/EVGA 3080 Ti FTW3 Ultra/Samsung 980 Pro 1TB/Asus 2540x1440p 165hz Gsync/Acer 2560x1440p G Sync 144hz
https://linustechtips.com/topic/736050-considering-buying-a-ups/
I would probably look for a 1300 VA UPS.  This should provide enough power to easily save any progress on your machine and perform a safe shut down.  I've had fairly good experience with APC as a UPS/Surge Protector.
I7 6700k OC 4.2ghz
EVGA 1080 SC
Corsair RM 750 PSU
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9343850
I have https://www.newegg.com/Product/Product.aspx?Item=N82E16842102048
And its very nice, at idle i think i have about half an hour to be able to shut the computer off. Havent tried it with load. (Build in signature)
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9344250
I7 6700k OC 4.2ghz
EVGA 1080 SC
Corsair RM 750 PSU
Your system shouldn't use more than just over 400W at load so units like theses below would be enough for the build, peripherals and networking equipment.
https://www.amazon.com/APC-Back-UPS-Battery-Protector-BR1000G/dp/B0038ZTZ3W/ref=sr_1_2?ie=UTF8&qid=1486766082&sr=8-2
https://www.amazon.com/CyberPower-CP1000PFCLCD-Sinewave-Compatible-Mini-Tower/dp/B00429N192/ref=sr_1_1?ie=UTF8&qid=1486766122&sr=8-1
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9344732
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9353764
3 minutes ago, JakovMatej said:
-SNIP-
In the future it would be best to make a separate thread but it depends on the speakers you have, for regular PC speakers it wouldn't add too much extra but go for the largest unit you have there the 1400VA. As for electrical damage a UPS will not do any good in a lightning strike, as the amount of current and power coming through is unpredictable.
https://www.nakupovanje.net/izdelki/racunalnistvo/zunanje-naprave-in-periferija/brezprekinitveno-napajanje/46649/apc-back-ups-bx1400u-gr-700-w-1400-va-brezprekinitveno-napajanje
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9353786
Got it.
Small home 5.1
https://www.cnet.com/products/creative-sbs-5-1-560-speaker-system-for-pc-wired-series/specs/
How about for voltage dips or brownouts?
The most concerned i am for now are the voltage changes, since from time to time i hear the crackling noise from my speakers, which i guess is from voltage changes, caused by some power dips in the neighborhood. Though the speakers have survived for a long time, so im not concerned about them, but i had 2 monitors which malfunctioned with similar issues. Thats why im asking if i could just use the UPS for monitor and pc and connect the speakers to a normal wall socket.
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9353871
10 minutes ago, JakovMatej said:
Got it.
Small home 5.1
Oh yeah that's not a problem nothing super major, a UPS will help with ensuring good quality power and smooth out brownouts, and voltage drops not to mention sudden power loss. It would be best to have everything on the UPS as the 1400VA unit will be more than enough and protect everything you have.
https://linustechtips.com/topic/736050-considering-buying-a-ups/#findComment-9353907
