1 minute ago, Frosty! said:
Hi guys
im curently using the EVGA 1060 3GB SC.
I wanna buy the BENQ ZOWIE XL2411
which cable do i Need to get 144hz
and Will it This cable fit into my GPU
Maybe anyone got a better 144Hz monitor for around 300€
https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v20/
Read here under "Connecting to a 120+ Hz monitor"
1 minute ago, Droidbot said:
Displayport
Your GPU has it.
The XL2411 doesn't have DisplayPort.
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342436
2 minutes ago, Frosty! said:
Hi guys
I have the Asus VG248QE :)
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342439
Displayport
Your GPU has it.
The monitor doesn't. I think I have the same model. 144 Hz is only on DVI.
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342444
5 minutes ago, Droidbot said:
Displayport
Your GPU has it.
Cant i just use DVI???
but has my GPU dvi?
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342452
My gpu had dvi-D is This Allright
or Should i buy a monitor with display port
which port is the best?
Both DVI and DisplayPort will be the same, but it is recommended to get a monitor with DisplayPort because it gives more flexibility than DVI. DVI is not found on laptops and also newer graphics cards are starting to discontinue DVI, so in a few years you may not be able to buy a new GPU with DVI, which means you would no longer be able to use the monitor at 120+ Hz.
The ViewSonic XG2401 is a better choice usually at the same price, it can do 120+ Hz over DisplayPort or HDMI.
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342461
Oke but is my dvi-D Allright??
is the viewsonic realy better because it is 40€ cheaper here in the netherlands
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342488
18 minutes ago, Mike87 said:
What about HDMI Port? O.o
XL2411 doesn't support >60 Hz over HDMI.
Yes, I have one and it works fine. Can get 144 Hz over DisplayPort and HDMI.
https://linustechtips.com/topic/735927-144hz-cable/#findComment-9342543
