Ive been trying to figure out why my graphics card cannot reach above 80% usage. It also has really bad spots where it drops to 20% and my fps goes into the dumpster. Main game is Rust and it is worst on that game.
i5 6600k
Gtx 1070
Z170A M5 MoBo
No overclocks
Every driver in this PC is updated.
https://linustechtips.com/topic/735695-low-gpu-usage-fps/
Maybe rust has poor optimization, or perhaps your 6600k bottlenecking? I don't know how CPU-heavy this title is. Maybe overclocking it would help.
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339875
Im 99.99% sure my i5 6600k is not bottlenecking but I could try a slight overclock so see if that works.
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339882
i5 6600k
Gtx 1070
Z170A M5 MoBo
No overclocks
What are the temps?
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339887
1 minute ago, Consepter said:
Everything is the latest driver, 0 overclocking in this system, only in Rust.
only is rust so that says that rust is not optimized for your setup. whats settings do you use ? have you tried turning down settings?
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339919
Yes but im trying to make the game look good aswell, haha I want frames and quality. I could try to put it to medium settings.
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339921
2 minutes ago, Consepter said:
It is sad because I see some of these benchmark videos with the same setup as mine and they are getting like 80-101 frames
seeing their cpu recommendations on minimum and recommended specs are "2GHz" and "3GHz" i think it's fair to say the devs arent competent enough to properly code multicore optimization.
does your cpu usage happen to float around the 25 or 50% mark pretty consistently?
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339955
2 minutes ago, Bob116 said:
I have a 1060 in my rig and in some games (minecraft, southpark ) the clockspeed goes from 2150mhz to ~1200 and framerates drop to 10-25.
southpark stick of truth runs on a 10 watt quadcore celeron with iGPU, that sounds like something else going on there :P
and minecraft, without any eyecandy mods (no, texture packs dont count) you may as well be running a 750Ti as a GTX1060 and have the same results.
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339966
Im hopping into rust to give you exact percentages
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9339990
1 minute ago, manikyath said:
i'm missing something here.. how would turning up settings help anything? (except if the game has a cpu multicore setting)
Gtav 1080p
@ medium 70-75
@ high  80-90
@ med gpu freq sits at 1200 mhz @ high it sits at 2150 mhz
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9340032
1 minute ago, Bob116 said:
Gtav 1080p
@ medium 70-75
@ high  80-90
but gtav is unrelated to rust, minecraft, or stick of truth, and that's defenately something thats not supposed to happen on a 1060 :P
https://linustechtips.com/topic/735695-low-gpu-usage-fps/#findComment-9340038
