hello everyone,
i'm about to build a new pc https://pcpartpicker.com/list/8MfZr7 and this time i want to use an ups since where i live now the power is not great. what do you think about this one: https://www.amazon.it/gp/product/B0042F0JMS/ref=ox_sc_sfl_title_2?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H
please if you have any suggestion feel free to share since i'm a total noob on this topic.
https://linustechtips.com/topic/735473-ups/
30 minutes ago, fede16071995 said:
-snip-
That UPS will work, but what kind of runtime did you want? Depending on how much run time you want, you might need to go up to the 1200VA model.
Also, do check if Eaton 5S (Sorry, not sure what the model is for you, I know the US models) is around. I'd personally recommend Eaton over APC.
https://linustechtips.com/topic/735473-ups/#findComment-9337040
16 hours ago, fede16071995 said:
hello everyone,
Yes that unit will work well for your system with peripherals and networking equipment.
https://linustechtips.com/topic/735473-ups/#findComment-9341119
