big case for modding ?
Go to solution Solved by Misinthe,
I would say something from CaseLabs. Like this
http://www.caselabs-store.com/magnum-th10a/
Hello everyone.
Im searching for a big case with side window, that supports:
ATX
2 PSUs
min 6 hdds
GPU: min 32.8 cm (12.9" )
CPU cooler: min 16 cm (6.3")
Support for a 240 rad or bigger.
included dust filters would be good, but not necessary.
The color doesn't matter.
I already looked at the antec nineteen hundred, but the quality seems to be very bad.
My location is germany and i don't want to import a case.
(Older/used cases are also ok)
https://linustechtips.com/topic/735365-big-case-for-modding/
Caselabs has the best quality.
https://linustechtips.com/topic/735365-big-case-for-modding/#findComment-9335848
1 minute ago, Admiraldeamlich said:
looks good. Any alternative ?
If you want best quality and modality, CaseLabs are your best option, they're based in California though, so you might need to import. But check around their website, you can choose so many things to add or take off of them.
https://linustechtips.com/topic/735365-big-case-for-modding/#findComment-9335876
Hey man I would say Caselabs since they have the BEST quality cases! But you mentioned your location, so 1. Guten Acht!  2. I would go with a bequiet! case since their actually a German company, their latest case the the Dark Base Pro 900 offers a Large amount of options, check them out man! http://www.bequiet.com/en/case/699
https://linustechtips.com/topic/735365-big-case-for-modding/#findComment-9335881
The 900 is actually to small, But still a nice case.
https://linustechtips.com/topic/735365-big-case-for-modding/#findComment-9335895
