LED Voltage dimming help
1 hour ago, dtaflorida said:Yeah I see a capacitor and coil on mine. It's just like your photo. This is it:
https://www.amazon.com/HERO-LED-SG4-12T-WW-Halogen-Replacement-Dimmable/dp/B00QE2TUDQ
So applying 18v or 24v won't make this any brighter than it is at 12v? My goal was not to provide it less voltage, I was thinking I could control brightness with by ranging the voltage from 12v to 24v since the bulb says input: 12v-30v.
The Vreg in the bulb will do its work and provide clean power to the LEDs as long as you provide 12-30v. Anything between that voltage range will result in the same brightness. Depending on the regulator type, higher voltage will mean more heat dissipation by the regulator. Anything higher than the specified max voltage will most likely release the magic smoke. However, if you lower the voltage below 12v, the regulator is forced to provide a lower voltage to the LEDs.
