Cooling with stock thermal paste from cm or SIlver 5?
Solved by Carter Bourne,
1 minute ago, Spork829 said:I mean those temperatures are well within safe operating range, so it's just fine for you to run if we can't figure this out. I would just make sure you're tightening down the cooler firmly (but be careful), and go back to the dot method, I find all the other ones to have no visible benefit over it and it takes the least effort.
Ok Thanks I am going to take off the cooler and remove the stock paste and add the silver 5 back
