Is it connected to the motherboard fan header? (specifically the one that says CPU)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/734613-cpu-fan-not-running/#findComment-9327108
maybe the fan is broken? If it's connected i see no reason it wouldn't spin.
did it just randomly stop one day or did you do something to stop it?
Laptop:
https://linustechtips.com/topic/734613-cpu-fan-not-running/#findComment-9327144
