I am thinking about building a server for Minecraft, Terraria, and maybe VPN hosting. Any input  on the components is appreciated. I have a PSU from another build that is 500W and 80+ Thermaltake which I am going to use.
Here is what I have so far:
PCPartPicker part list: https://pcpartpicker.com/list/WWkgpb
Price breakdown by merchant: https://pcpartpicker.com/list/WWkgpb/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ Newegg)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($86.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  ($58.88 @ OutletPC)
Storage: Toshiba P300 1TB 3.5" 7200RPM Internal Hard Drive  ($48.99 @ Best Buy)
Case: Cooler Master CM 590 III (Black) ATX Mid Tower Case  ($61.46 @ Newegg Marketplace)
Total: $496.31
Generated by PCPartPicker 2017-02-04 22:24 EST-0500
The  page says  that the power consumption will be 179Watts under max load (which I know I will never really be reached). I was wondering what you think the wattage drawn from the wall would be with a Linux OS and a Terraria and Minecraft server without anyone online? Also, what would it be when they were both under load? Note: These would be private servers with no more than 5 people on at once to start. I am trying to figure out how  much power this system would use overall. Finally, I know that this Xeon is very powerful. Do you  think I could host a Terraria and Minecraft server off of a 2-core 4-thread Pentium? It  would be only 51 Watts which would be nice. Ex: http://ark.intel.com/products/97453/Intel-Pentium-Processor-G4600-3M-Cache-3_60-GHz
https://linustechtips.com/topic/733439-server-power-consumption/
normal idle power is around 60w.
You need a gpu, so id get a 1246 so you have a igpu.
Id get a pentium or i3 personally with that few users, or a j1900 like system to save power.
TDP != power consumption. My e3 1231 v3 Don't user more than 55w and has a 80w tdp
https://linustechtips.com/topic/733439-server-power-consumption/#findComment-9315092
Thank you
https://linustechtips.com/topic/733439-server-power-consumption/#findComment-9315127
TDP is not an indication of wattage used. It indicates wattage dissipated.
I would suggest buying a server board. They'll use less energy since the modules on the Z97 that aren't used still have to draw energy. But if you have the parts, never mind.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/733439-server-power-consumption/#findComment-9315145
