EK is good.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309629
5 minutes ago, Panda255 said:
Im new to watercooling and want to know any good kits out there that has everything already i know Ek has some but just wanted to know if theres any other ones i should know or you recommend
The P series kit have my vote, they have the better D5 pump units.
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309634
2 minutes ago, Panda255 said:
You know gpu's that have waterblocks already on them?..Does this kit support them? I guess i forgot to say that
They are no different than a custom loop so you can mix and match components add more blocks and rads as needed. As for GPU's with waterblocks already on them are are some options out there EVGA being one of them:
http://www.evga.com/products/product.aspx?pn=08G-P4-6299-KR
https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1080-arcticstorm
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309690
I would just need some more tubing right?
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309694
You should be ok with the length they give you usually it's with a bit of extra, you will however need some extra fittings and if your plan on overclocking both CPU and GPU I would recommend to look in to P360 kit
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309699
Okay sure will, Thank you for all the help
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309703
Umm Anychance you know the thermal take kits at all? Im in canada and that kit is in usd price which is a lot more then it is but the thermal take one is the same price but in canada soo do you think its worth paying the extra 200$ ish for ek?
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309780
Don't get the Thermaltake ones they're not recommended as they are mixed metal loops and don't have the best pumps.
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309798
2 minutes ago, W-L said:
It depends on which ones they do have some good ones.
https://www.newegg.ca/Product/Product.aspx?Item=9SIAA5K3RH3163&cm_re=Alphacool_kits-_-9SIAA5K3RH3163-_-Product i noticed this went up in price a lot which is around same price as Ek so might go with Ek
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309816
They're good the only thing is with the bay pump res combos units they tend to pass vibrations readily through to the case making excessive noise. The tube res versions are much better in that regard.
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309825
Okay..I'll do research and see if i go with Ek or Alphacool
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309834
Okay sorry to keep bugging you...http://www.ncix.com/detail/ek-kit-l360-r2-0-watercooling-kit-99-108169.htm Is this the same ek kit?
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309902
No worries the L360 kit is not bad that uses the DDC series of pumps which is also good just a little more audible than the D5, and a thinner radiator.
https://linustechtips.com/topic/732850-watercooling-kit/#findComment-9309933
