Need help adding a switch to my network.
2 minutes ago, M.Yurizaki said:I think I'm confusing myself and making you confused, after re-reading your OP.
You're supposed to connect your stuff in the way I described earlier: Modem <-> Firewall <-> Router <-> Switch. This is if you need all your devices connected on a LAN and be able to access the internet. This is my setup at home, minus the firewall.
If you're trying to create two separate networks that can talk to each other, that's beyond my scope of knowledge (a cursory look at switches suggests some more advanced ones can setup VLANs for this purpose or something). But if its for security reasons, they should be air-gapped anyway.
I solved it. It was because the item my PoS sent with tier set up was a router NOT a switch. I turned off my wifi on one of my desktops. I hooked the "router" from them to the desktop by lan with nothing in the wan port. I logged into the browser set up. disabled DHCP and added a static IP different then everything else. I then took the Lan from my switch in my office and connected it to the new switch ( the router but I turned off the DHCP which means it isnt trying to grab anything anymore) into a lan port ignoring the Wan port. Then I took another lan into the pc and all is well now, Wifi works and all of it. So thanks for the support man!
