Maybe just try powering it down and then unplugging and plugging it back in. Are you using a modular psu?
The only reason I'm here is that I have homework that I don't want to do
PC  Specs   CPU: Intel Celeron N3060 |GPU: Intel HD graphics 400 |RAM2 gigs  |STORAGE16 gigs
It took me half an hour to find where to change my signature :(
https://linustechtips.com/topic/732727-i-havs-an-problem/#findComment-9308362
That means that the gpu is not getting enough power from the psu.
I know this sounds silly, but check the plugs where the 8pin pci cable plugs into the PSU...
If you have a case with psu cover then you cannot see if the pci cable is loose from the PSU. That happened to me before where I'm trying to check the connection between the pci cable and the GPU but didn't know that the PCI cable is actually loose/not connected to the PSU, it may get pulled out from me trying to do cable management after building the PC
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
https://linustechtips.com/topic/732727-i-havs-an-problem/#findComment-9308403
It should be 6+2, not a pure "8 pin" connector.
Is it plugged on both the PSU and the GPU properly?
Is it plugged where it should be plugged on the PSU?
Be sure it's firmly pushed in, if you can remove it without lifting the little tab, it's not pushed in enough.
What is the wattage of your PSU and what is the GPU ?
https://linustechtips.com/topic/732727-i-havs-an-problem/#findComment-9308408
