With all the servers stuff that Linus have put up over the years,, I'm quite tempted to build a box for myself but I need some help in optimizing my build for the use case:
It will be a central NAS to all my media stuff.
It will be a router/ wifi access point so that internal network speed will not suck and I can have some mesure of control over my network.
It will be a seedbox so I don't have to use my main rig to download stuff.
So, what kind of hardware do I need to use? Software as well and if you can point to any tutorial on the matter it would be highly apreciated.
System Spec: H87 mobo from Zotac, I3 4130, 4GB ddr3 1600mhz Cas 11, WD green 2TB all in side of a Cooler Mater Elite 120
https://linustechtips.com/topic/732323-the-do-everything-box-need-help/
Do not make it into a router/AP. Get something like an edgerouter lite and a uap-ac-lr. You can get an r210 II off ebay for $200, and run a hypervisor off of it for your seed box and media server.
My native language is C++
I'd make a router a separate box just so when you have to dork with the server the rest of the network doesn't go down with it.
I'd use unify aps for wifi
For hardware I'd get a used dell c2100 if you don't mind the rack form factor.
For os I'd run something like linux with kvm and run all the services in a separate vm.
not to great with server parts but from what i can tell you will probably want a 10 gigabit network card. I also might be wrong about this but I think you need a separate device for networking(a switch/access point ect.).
No need for 10gbe for most users.
So the servers and the Router/AC point must be separate so that when I dork with it the network does not goes down? Good point.
So how does one build a NAS? For a resident of 3 people total with 6 devices total what would you think spec wise would be enough.
Thanks for all the inputs!
It depends on what you already have. (Any HDDs, RAM or other hardware you might be able to reuse)
Depending on your budget you could either get:
- A rather capable synology/QNAP NAS
- As it seems like you might want to play around with the box a bit more (using it as seedbox and later maybe other stuff) I would probably go with a DIY built system using
-> FreeNAS or
-> UnRaid
In this case for hardware it again depends on your budget. Probably sth like this:
CPU: i3 (maybe i5)
RAM: 16GB (ECC -> especially for FreeNAS)
MoBo: Suitable for your CPU and RAM, preferably with an Intel Gig NIC, some SATA ports and pcie expansion capabilities
HDDs: Depending on how much space you need, Currently 4TB NAS Drives have the best Price/Performance (at least here in germany)
SSD: None for FreeNAS; 64-250GB as Cache for Unraid
A suitable Case and PSU (depending on how much space/power your system needs)
UI/UX Designer
CPU:
Intel i5 6600k @ 4.4GHz, Noctua NH D-15, GPU: MSI GTX 970, RAM: HyperX Fury 32GB (2x16GB) DDR4, MoBo: AsRock Z170 extreme4 ATX, Storage: 250GB Samsung EVO SSD + 128GB Toshiba M.2 SSD + 1TB WD Blue, PSU: Antec 650W, Fractal Design Define S
it's not great idea to have everything in one box
something like virtualization, yea thats ok
but mission critical devices like a router should be separate and not integrated into other devices
but i get what you are trying to say, a NAS and seed box would be good idea to integrate into one system
just make sure that the seed box has it's own network port to use otherwise you will have a network bottleneck when you are using both the NAS and seed box, i would run Ubuntu or other Linux distro for the seed box and give it
2 core's 4GB RAM and 25GB or more storage
also code name it the "Go Everywhere, Do Everything BOX" that sounds cooler
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
