hey all.
I have come for some help and advice again.
Ive been researching like crazy but cant find a way out.
My girls pc keeps getting random BSOD's (clock_watchdog_timeout)
From research it was AI suite 3 was causing the issue and we removed that fixed the issue for a while. Then we had to reinstall her pc and a fresh installation of windows 10. Everything went fine i mean it was peaceful (for about 3 weeks) until now and she got the random bsod while launching a game (ghost in the shell first assault)
from the logs:
Level	Date and Time	Source	Event ID	Task Category
Error	2017-02-02 18:25:59	Application Error	1000	(100)	"Faulting application name: KaveXTDMonitor.exe, version: 0.1.0.29, time stamp: 0x52d35cfb
Faulting module name: osConfLib.dll, version: 1.5.1.1, time stamp: 0x52294f8b
Exception code: 0xc0000005
Fault offset: 0x000000000000cd6d
Faulting process id: 0x1b20
Faulting application start time: 0x01d27d796b17b3ae
Faulting application path: C:\Program Files\Roccat\Kave XTD Headset\KaveXTDMonitor.exe
Faulting module path: C:\Program Files\Roccat\Kave XTD Headset\Driver\x64\win81\osConfLib.dll
Report Id: fac59968-4f02-4c40-9c5c-2ef14215a964
Faulting package full name:
Faulting package-relative application ID: "
Any advice or a fix for this?
Thanks in advance!
https://linustechtips.com/topic/732290-clock_watchdog_timeout-issue/
Is the CPU overclocked? Because this error usually appears when an overclock has failed....
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
we have set her bios to default and its been running smooth ever since for about 3 weeks and now this. cause its really strange why would it overclock itself when its set to default.
11 minutes ago, BloodyWaters said:
Delete that program? Can't think of anything else.
if i delete it her headset aint working correctly.
Just to make sure.... Reset CMOS and check if the issue persists...
what CPU are you using?
i know for a fact that windows 8 and 7 don't like +5Ghz clocks on CPU's as they crash
are you running kaby-lake? if so are you running windows 7 or 8?
if so upgrade to 10 as thats officially supported.
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
18 hours ago, RuschGaming said:
as in cmos reset will updating the bios and reset it help as wel?
Load optimised defaults in the BIOS....
yup we have done that but same results
I have asked her to get an USB stick and later we are going to try to update the bios see if that resolves the issues
