Finally got an adapter to use my third screen, but then... https://imgur.com/a/ke9w1
Can someone explain why everything goes up so much when using a third screen? And is there a fix for it? I don't want my graphics card to idle at 60C.
Main: Gigabyte G1 980Ti, i5 6600k, MSI Z170A M5, 16GB DDR4 2666, NZXT H440, NZXT x61, EVGA 750W G2, Windows 10
Second PC: EVGA Reference GTX 680, i7 2700k, 16GB DDR3, Corsair 300R, Corsair CX500W, Windows 10
Laptop: Acer Aspire 5750G, GT540M, i7 2630QM, 6GB DDR3, Windows 7
https://linustechtips.com/topic/732228-gpu-temp-increse-when-using-3-monitors/
10 minutes ago, TheNuzziNuzz said:
Specs?
It's my main PC in my signature.
10 minutes ago, mok said:
seems fine...
your GPU is powering 3 times the resolution compared to a single monitor
you could try powering your second two monitors off the motherboard isntead
Okay, but having 2 monitors doesn't affect my GPU at all. And i don't want my GPU to idle at 60C.
are any of your monitors running more than 60hz?
i know 144hz monitor cause GPU's to idle much warmer
Photography / Finance / Gaming
Nope all 60hz.
have you tried different drivers?
I run 3 x 1080p @ 144hz and 2x 1080p @ 60hz, I have ran into high idles many times with just installing new drivers I usually revert back until another comes out to try, also run 3 cards too all idle at 30-40 now
