Hyper 212 coolermaster cpu cooler issues
Hello I have a hyper 212 coolermaster cpu cooler And when my pc is standing upwards the thing has a rattling sound 24/7 But when I laid it down on my carpet and listened no sound at all what's the issue?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/731795-hyper-212-coolermaster-cpu-cooler-issues/
Btw I'm using a fx 8300 8 core processor am3+ I believe
RAM: 32gb ddr3
2 minutes ago, 8-Bit Ninja said:
Are you sure its the cpu fan, and not the case?
I'm sure
RAM: 32gb ddr3
I thought the cpu fan was to big for my case so i took the front panel off and it still made the noisebut when I laid it down no sound at all
RAM: 32gb ddr3
have you tightened the screws that hold on the other side panel?
Yea why? There as tight as They can be the rattling noise only starts five mins after I start the pc up
RAM: 32gb ddr3
Make sure that the fan cable or any other cable for that matter is not hitting the fan when it is spinning. Also, check to make sure that the 212 evo is secure on the motherboard.
1 minute ago, Generallee said:
Check if some cable touches the spinning fan
It could be as simple as a bad fan as well.
PSU Fan maybe?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
