NZXT CAM
Go to solution Solved by MorganO,
3 minutes ago, Bananasplit_00 said:
well do a google on programs that can nuke installs, that would be your best bet probably. i dont really dare recomend anything because i dont know what i used when i had to nuke some stuff
i used a shady thing called iobit unistaller which then i swiftly removed afterwards
so i cannot remove nzxt cam this incredibly inconviencing as i need to downgrade cam as it is broken for me
can anyone help?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/731416-nzxt-cam/
delete all the files? might work
Builds:
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293377
currently in the process rn
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293383
ok well get back to me how that goes, i think there are some programs that lets you just nuke installs otherwise. i had to use one to get rid of shit before
Builds:
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293395
nope its not working :/ it keeps showing up as another veersion of NZXT cam is installed
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293402
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293758
Builds:
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293884
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293902
Just now, Rangaman42 said:
It could be a registry issue?
i think it could have been
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293909
good move, great that you got it fixed :)
Builds:
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9293988
can anyone help?
THIS SAME THING HAPPENED TO ME A WEEK OR SO AGO!  WHAT THE HELL NZXT!  Fix your Software!
But aside from writing a rant.. I just put the error aside and said "I'll fix it later.." I'm glad I stumbled upon this thread!
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9295482
Any chance you can link me to it?  And it wasn't TOO shady was it? Don't need any malware haha
im not blaming NZXT for the uninstall issue, more that win10 was being retarded
http://www.iobit.com/en/advanceduninstaller.php
https://linustechtips.com/topic/731416-nzxt-cam/#findComment-9296515
