i would like to use my iMac as a monitor to accompany my laptop which does have a thunder bolt 3 port but my iMac doesn't i was looking online and could not figure how to do it
i would like to know for certain how to do it before i buy adapters or anything
thank you
https://linustechtips.com/topic/730969-using-imac/
https://support.apple.com/en-us/HT204592
System Requirements
You need the following to use Target Display Mode:
See the list below for iMac models that support Target Display Mode, the type of cable you need to connect that model of iMac, and the kind of port you need on your other Mac.
iMac models you can use
as a display
Cable
you need
Port you need
on your other Mac
iMac (27-inch, Late 2009)
Mini DisplayPort to Mini DisplayPort
Mini DisplayPort or Thunderbolt
iMac (27-inch, Mid 2010)
iMac (Mid 2011-Mid 2014)
Thunderbolt
Thunderbolt
iMac (Retina 5K, 27-inch, Late 2014) and later iMac models can't be used as Target Display Mode displays.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/730969-using-imac/#findComment-9288232
16 minutes ago, mashmaster said:
thank you anyway it's a shame apple are a money sucking corporation
It's an all in one computer, not a monitor. Why should it even work as a display for another computer in the first place? OSX is required on both computers because it is an entirely software solution.
https://linustechtips.com/topic/730969-using-imac/#findComment-9288451
