A few days ago I upgraded to z270 and 7700k from z170 with 6700k (ik thats not worth the performance gain), and I was experiencing really bad temp from there :( idk if it is the mobo or the 7700k. I am using the nzxt x52 aio. 37-40C idle, 70-75 during cinebench for stock and temps are gonna fly for a 1.3v OC, 90-100C underload (not even aida 64). Then I delidded my cpu (well the first time ever done this) and replaced it with mx4 (liquid metal still on the way). OH forgot to mention the temps above are after delidedding, B4 that the temps are worth, like over 80C playing overwatch at stock speed at voltage.
https://linustechtips.com/topic/730663-need-help-with-cpu-temp-7700k/
Whys the voltage so high? what clocks are you running?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
was running 4.9 for 1.3v. but the temps i stated were for stock speed and voltage
3 minutes ago, Howitz said:
DELID IT! B| lol don't
exactly what i did, doesnt help much, well it did a lil bit
DELID IT! ;P
read the OP:
Quote
OP already has!
How were the 6700k temps on that cooler?
Ryzen Ram Guide
9 minutes ago, CainCo said:
You need to lower your voltage most likely
best thing to do is a stock re-baseline the CPU after the delid.. sounds like the CPU mount is fouled, the MX TIM isn't covering the die, or your overvolting is too much.
the stock baseline will affirm the mount and voltage issues.
What are you using to monitor temps? I had an issue years ago that needed a bios update as it wasn't reporting temps correctly.
Ryzen Ram Guide
cpu temps are better b4 cpu was delidded, said it in the first post
Ryzen Ram Guide
1 minute ago, CainCo said:
over 80C at stock voltage with aida 64 actually over 85C, i dont consider that normal
Watch the review and read this, the Z270 boards have issues with using too much voltage
http://www.gamersnexus.net/hwreviews/2744-intel-i7-7700k-review-and-benchmark/page-4
4 minutes ago, NannerBeans said:
When you take the cooler off, does the thermal paste look evenly spread and it's in a thin layer?
yea i did it a couple times im sure theres no problems
hw monitor and the msi on board cpu temp reporting thing, showing  the same number, and theres only one bios version for the new z270 mobo
Try stock again and dial the voltage back to lowest you can get it whilst it remains stable at stock clocks, see how temps are then
Ryzen Ram Guide
If you're having the same issue with both the 6700k and the 7700k, then the likely issue is with your cooler.
7700k temps are like 10-15C higher than 6700k (both stock same cooler same thermal compound
8 minutes ago, airdeano said:
but nothing about what voltage at stock...
Yea ur right but I can manage to get under 80C at 1.37v for 6700k under aida64, 1.3v at 90-100C during cinebench is simply too high
Lower the core voltage, I lowered my to about 1.26V (effective volts is lower) and I dropped about 20C. It was hitting 100C but now it stays around 80C at max.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Good thing you used all caps, otherwise nobody would have been able to hear your post. 9_9
Anyway, as others have said, lower the voltage.  It's way too high.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
ik how to make it safe just saying it's not normal and i really wanna hit that 5Ghz that's the reason I upgraded for 6700k
Well 5Ghz is so hopeless
It's also a ridiculously high overclock.
msi needs UEFI help.. TTL and others have basted msi for their slow to help UEFI updates.
you'd have to do a manual undervolt stock to restart. i wouldn't do much until the engineers can sort out their voltage issues. asus has already found newer UEFI to lower temperatures and better performance.
