I have problem with my case Fractal define R5. After some time it started buzzing. When I put finger on it buzzing stopped. I think that sound is coming from HDD cage. Also when side panel is removed there is no buzzing sound, so I think that HDD vibrates and vibration goes to side panel. When dust filter is removed buzzing continius so they are no problem. Any recommendation how to fix? Where can I put some adhesive foam or something to stop buzzing? I just testd it for two days so I am not sure about all facts.
https://linustechtips.com/topic/730499-case-buzzing-sound/
Find out exactly where its coming from. Probably the side panel screws.
Computers r fun
https://linustechtips.com/topic/730499-case-buzzing-sound/#findComment-9282945
I had this issue, it means your HDD isn't screwed down tight enough. I just tightly taped it to the side to stop the buzzing.
https://linustechtips.com/topic/730499-case-buzzing-sound/#findComment-9282957
Today I tested with side panel removed. No buzzing sound, only maybe a little buzzing when I put my ear on a close distance near hdd cage. My hdds in cage are rotated by 180 degree, they connection is on a left side on the panel, ussualy on the internet pictures is on the right side of case. No hdd cage rotation, only hdds. Could that cause buzzing? Tomorrow testing continuous.
https://linustechtips.com/topic/730499-case-buzzing-sound/#findComment-9287216
  • 3 weeks later...
