My southbridge is inverted upwards. Need help
Solved by W-L,
6 minutes ago, dialgarocksful said:I see... Is there any tools I need to use in order not to destroy the pins or bare hands will do? Btw, is there any thermal paste underneath it that needs to be replaced if I remove it?
You should be able to just pull up on them by hand without any problem. The heatsink should have thermal pads which can be reused but if it has paste you will want to re-apply.
Featured Topics
Beeswitt ·
Posted in Troubleshooting0 -
3
CrowTheRobot ·
Posted in Windows1 -
1
6
uncanny_mac ·
